Hanginon wrote:
My concern with the RR tests being done in Finland and the Netherlands is the use of the Diamond Plate drum. Diamond Plate typically has approximately 4mm bumps. This is much larger than even the worst roads I ride on here in the US. Go ahead - take a ruler outside to the road and look for yourself.
While the so-called hysteresis losses should extrapolate to smoother surfaces,
does anyone know this for sure? Reading this thread you can see that the whole wheel/bike/rider combination is very complex. IMHO, a wheel held rigidly (no fork), with the tire riding over 4mm bumps, doesn't simulate what most of us are doing.
Has anyone done similar tests with a smooth(er) drum, and also at higher speeds (more in line with what the riders on this site ride on and travel at)??
The fact that most of the common tires tested by myself and BRR typically differ from each other by the same percentages, points to the fact that when tested at pressures below typical the breakpoint pressures experienced outside, both the smooth rollers and diamond plate covered drums give a valid estimate of the "outside" Crr values, with the only difference being a multiplication factor to go from the test values to the expected outside values. This makes sense if you realize that all the diamond plate is doing is causing "extra" flexing of the casing, as compared to the smooth roller, with the resultant addition material hysteresis losses.
My own testing, and some testing done by Andy Coggan a long time ago suggests that the "smooth roller to flat outside" data correction is going to be in the range of ~1.3 to 1.5X. The correction for factor for a diamond plate roller is going to be less.
The above is part of the reason I don't see a need for adding "texture" to the roller testing. The smooth rollers tell you all you need to know about the tire material properties when used reasonably (i.e. not over-inflated). But...people look at the smooth rollers and think "that doesn't reflect reality" and try to add in "roughness", even though it's not telling one anything additional in the end.
Now then, if one is interested in finding the "breakpoint pressure" of a particular tire/loading/speed setup, that's going to require a test fixture that incorporates some SIGNIFICANT damping between the wheel and the load mass (or forcing element, such as an air cylinder, like is used at Wheel Energy, from what I understand), so that it can mimic the damping losses in a human body. I have yet to see a test setup that does so...besides, field testing for Crr using Virtual Elevation methods outside do a pretty good job of that evaluation, so why not just do that instead?
Roller testing for tire ranking (to find the good ones), then VE testing for pressure evaluation is my recommendation...or, just use the Silca pressure calculator for the latter to save even more time ;-)
