littlefoot wrote:
I have 52x36 on my roadie with an 11x30 cassette. I like the range of options.
My tri bike has 50x34 with an 11x26. I am thinking about changing it to the 11x30 cassette or 11x28.
If I keep the 11x26 how does that compare with the 11x30 on the roadie? Same, easier? Riding a TT bike uphill doesn't ride the same as the roadie (obviously).
Look at the ratio between the chainring and cog.
36/30 = 1.20
34/26 = 1.31
1.31 is higher than 1.20, so the low gear on the TT bike is higher than the low gear on the road bike. By how much? 1.31/1.20 is 1.09, so the TT bike's low gear is 9% higher.
You can also do algebra to figure out what cog size you'd need on the TT bike in order to match the gear ratio on the road bike.
34/X = 1.2
34 = 1.2 * X
X = 34 / 1.2 = 28.33
So, the 11-28 cassette would be pretty close to giving the TT bike the same low gear as the road bike. It would technically still be
slightly higher, but it would be close.
Note that this all assumes that the diameter of the inflated wheel is the same in both cases.
If two bikes have 700c wheels, but one has 23mm tires and the other has 28mm tires, this could result in an inflated wheel diameter of something like 675mm for the first bike and 685mm for the second bike.
685/675 = 1.015.
So, "the same gear ratio" would be 1.5% higher on the second bike than on the first bike, because of the second bike's larger rear wheel.
Quote:
but not sure if I need to or not.
Depends on your strength, pedaling style, and the terrain you're riding. Are you bottoming out your gearing frequently on the TT bike right now?
