Skoalz wrote:
The pandemic and an empty nest has allowed me to regain fitness I haven't had in years. As the title suggests, I have solid, but not top shelf, equipment. Assuming I can't get into a wind tunnel, where do you see my best options to pick up some speed with my bike equipment? Is the DA giving up much to new bikes?
Tires will be replaced in the spring with ???
2014 Felt DA4 (bone stock except powermeter)
1993 Specialized Trispoke (Hed3), clincher
2010? Renn 555 disc, clincher
Latex tubes
Front tire = Bontrager R4 Aero 22c
Rear = Specialized S-works Turbo 24c
Helmet = Giro A2
BTA bottle mount
Thanks in advance,
Scott
1. Keep the bike/frame if it can fit your body and desires on the bike. Least of your possible gains.
2. Ditch the HED 3 unless you only race on baby smooth roads. I tested mine out before selling it, and it is still a really fast wheel.........BUT....needs great roads so you can run the right tire and pressure for it. Around here, that doesn't work out so great. So I sold mine to a track racer happy to take it off my hands. Perfect place for an HED 3. Low yaw on a track and smooth riding. Get a modern 90mm front wheel instead where you can run a modern size tire at a comfy and fast pressure. You can possibly gain some CRR there and some watts at yaw over the HED 3. Ditch BOTH of those dog tires. Get a modern front wheel you can run a latex and faster tire. Refer to bicyclerollingresistance.com for some numbers to aid your choice.
3. Keep the Renn if you can run a 23mm on it in the rear. The DA should shield the rear wheel transition from frame to tire to wheel pretty well. My older DA did when I ran a 23mm on my Renn disc. Just get a better tire with latex tube. GP5000 minimum, preferably the new Michelin Power TT.
4. Get something that allows you to tilt the cockpit some, that's usually worth some comfort and a little aero. Tilt block shims, etc...
6. I found 10w between a really good TT helmet and the TT helmet that tested fastest for me so far. It's worth buying and selling a few and testing them out. You may lose $40 each time on shipping and resale, but $40 if you find 10w.........that's great. For most though, the Giro A2 is pretty darn good to start with.
Remember, the frameset (if it fits you) is almost always the last place to look for watts.
If I were you my shopping list would be:
-used HED 9+ front
-23 or 25mm Michelin Power TT front tire, 23mm rear for that Renn disc
-latex tubes
-cockpit tilt kit
