Hi guys, seems that i have developed a blister on the side of the bony area by the big toe. This happened after a 7mi run but i could feel it coming in shorter runs to. This shoes used to be great, stopped running after march close downs and now that i am getting back i am getting blisters. The shoes do have elastic laces. Any suggestion what could be causing this? Could it be the lacea are stretched/worn and i need to get rid of them. Any other ideas? The shoes are Altra Torin 4.0.
Re: Blister after 7mi run with shoes that fit well before [transam2k4]
My guesses are your feet lost their callouses, tied too tight or different socks.
Re: Blister after 7mi run with shoes that fit well before [Tri.Tony]
Tri.Tony wrote:
My guesses are your feet lost their callouses, tied too tight or different socks.These were my first thoughts as well.
You could also try using body glide or other anti chafe creams. Try different socks as well before you abandon the shoes.
Most likely you lost some strength in your lower leg and feet and you are just not as ‘ stable’ on your feet as you used to be.
Jeroen
Jeroen
As mentioned, probably just lost some calluses. In the meantime; use some lube, blister-proof socks, or athletic tape.
It's less likely that anything changed with the shoes.
ECMGN Therapy Silicon Valley:
I had blisters pop up after YEARS of never having them- in basically every shoe that I tried. Super corny, but I switched to the injinji toe socks, and this eliminated all the blisters.
Your feet got fat
"What's your claim?" - Ben Gravy
"Your best work is the work you're excited about" - Rick Rubin
Re: Blister after 7mi run with shoes that fit well before [RandMart]
RandMart wrote:
Your feet got fat
Re: Blister after 7mi run with shoes that fit well before [Titanflexr]
