tttiltheend wrote:
dfru wrote:
japarker24 wrote:
dktxracer wrote:
What about a
Trek Domane? It’s rated for 38mm tires and will hold 42’s. My wife has one and I’ve tested 42s. It’s really smooth on road and chews up the miles, although it isn’t the sportiest handler..
This is what me & the Mrs have. 2 sets of wheels: 1 set with road tires & 1 set with gravel tires.
What kind of gravel are you using the Domane in? How are you finding it for a gravel bike - I would suspect I am going to be 70/30 road to gravel, but I don't want a bike that doesn't get the job done...
My wife recently got a Domane SLR6. We recently did a 65 mile ride w/ about 70% gravel, including some pretty rough unmaintained Class IV roads and she did fine. The bike is very confidence inspiring, it rides really smooth and she's killing the downhills on it. If you do want to start doing pretty rough gravel or trails where you want 47-50mm tires then obviously you'd want a dedicated gravel bike. Also, it's not the lightest frame around. Her 44 cm bike is about 19 pounds with 32c GP5000 on some pretty light wheels, a pretty heavy Cobb saddle, Favero Assioma pedals, but otherwise stock Ultegra, and a bit under 21 pounds in gravel mode (wide tires and mtb pedals) with the stock wheels, which aren't the lightest. Obviously if you're willing to spend the bucks you can get it lighter but I don't think you'd ever get this bike down to 16 pounds without crazy exotic stuff.
She's running 40c tires which run on the small side and measure out to 39mm and clearance is fine. But at least on her size frame I wouldn't run anything wider. I think 42mm wide which another poster mentioned is really pushing it unless there's more clearance on larger frames, you might get away with it on dry stuff but could definitely cause real problems in the mud.
I recently got an Aspero and plan to use it for both road and gravel. As test I set it up for road and held my own in a fast group ride, even had a very good time for me on a short hill climb but don't currently have power on this bike so can't really compare with my aging but still light roadie. Swapping wheels is no big deal IMHO. However, the compromise comes in two other areas. I am using SPD mountain bike pedals for gravel and really wouldn't want to use those for fast road rides, and adding a pedal swap on top of the wheel swap starts to get into PITA territory. The other compromise is in handlebar shape and position. For gravel you generally want to ride a higher handlebar position so for road riding I have to bend my arms more to keep from being too upright. The Aspero comes with flared bars and I find that wider drop position is awkward on the road. But lots of people don't use flared bars for gravel so if you are primarily doing road then I think you could set up your bars for the road riding and be OK.
So just some stuff to think about.
Thanks for the feedback, guys! Awesome stuff, and plenty to think about. Between the Domane and the Checkpoint, just wasn't sure the Domane wasn't enough bike for fire roads and logging roads - I don't intend on trying to make it do mountain bike stuff, and the Checkpoint is hard to come by at this time.
Thanks again - GREAT info....
DFRU - Detta Family Racing Unit...the kids like it and we all get out and after it...gotta keep the fam involved!
