TRIPRO wrote:
Once-a-miler wrote:
Dimm wrote:
I bought a new P-series Di2 with these brake levers. This is my first tri bike so difficult for me to properly compare/calibrate my impressions, however I feel something is amiss. These brake levers are hard plastic and quite big - they are generally not bad but for some reason my hands always tend to slide back to where the brake lever meets the base bar instead of sitting right on the lever/handle. Not sure whether I do it instinctively to have a safer grip or there is another reason, but it doesn’t feel right. Also, because of the Di2 buttons’ locations on the insides, I sometimes hit the buttons accidentally with my thumbs when moving from the aerobars. What are people’s experience with these levers (especially compared to alternatives)? Do you find the handle comfortable and how do you grip it? Thanks.
Dimm
I just picked up a new Felt IA with these levers. I having the same issues as you. They are too wide and hard plastic. Not comfortable at all. Functionality, the brakes work great and I like have the buttons on the right hand but these things need to go!
I actually like them, they feel robust and solid :-)
Jeroen
How do you grip them?
I was on the trainer today trying different hand positions on these levers and came to the conclusion that sliding my hands back is probably the right way to grip them (whether it was designed this way is a different thing altogether though). If my hand is at the farthest end of the lever body, my fingers are touching the lever where it just exits the lever body and turns back. So applying any force to the lever at that point is very difficult. Also, the lever body is a bit too wide even for my relatively large hands (I am 6’3 plus) at that location (plus a bit slippery). However, if my hand is partially on the base bar and partially on the lever body, the width is appropriate, the grip is more secure and I have access to the lever with my fingers at the right point and can easily reach the Di2 buttons. But there is probably 5-6cm of unused lever body sticking in front of my hand which is a bit bizarre.
So frankly, if I was sure that I would hold on to this P-series for quite some time, I would probably replace these levers. But in my case I think they are what they are, and I am not planning to be on my base bar for extended periods of time anyway.
Dimm
