Painfree longitudinal tear of posterior tibial tendon.
I'll lead off with the question - has anyone ever had a really long split tear (9cm) of the posterior tibial tendon (as seen on MRI), but been able to run pain free and to do things like multiple sets of single calf raises? If so, how did you handle it?
History:
So... I have a long history of instability in my right ankle, with damaged ligaments. In 2014, I did several rounds of PRP and prolotherapy, and that fixed stuff up.
Starting late last summer, I started to have some posterior tibial pain on that right side. It was never awful - the pain was at most a 3 out of 10, and I could do sets of single calf raises on that ankle, though it was slightly weaker than the left. So I got it checked out by a podiatrist, who wasn't too worried about it, and then did some PT. It never stopped hurting, but never threw off my gait or hurt that badly, so I just stuck with the PT, kept running, and even ran some PRs.
It kept burning, so late last year I went back to the podiatrist - he ultrasounded it, and noted that the tendon looked really good, though there was a small bit of fluid near it - nothing concerning. He also noted, oddly enough, what looked like an accessory post tib tendon. But overall, it looked fine - just one of those things that might be painful for a while. I also went to the doctor who had done my previous PRP/Prolo - he examined me and thought the ankle was fine.
The ankle kept burning on and off, with the specific point of pain starting to move around - it'd be in front of the medial malleolus, then behind, then up on the shin behind the tibia. Then gone for a while. And it didn't really correlate with intensity of exercise, while it would start to throb when I lay in a certain position. All of which pointed to a back issue. At the same time, I was also having repeated bouts of left leg posterior pain, triggered while running, that would come and go. I was doing PT regularly, but not seeing much progress.
So we decided to get a lumbar MRI. And also an MRI of the right ankle, just to be complete.
While waiting for the MRI appointment, my PT decided to try a different taping technique - basically Mulligan taping, but starting on the medial malleolus, rather than the lateral. It was a game changer. Left leg pain disappeared, right ankle burning disappeared - yay. But I got the MRIs anyway, just because.
I got back the MRI reports a few days ago - the lumbar back looks totally fine. But the right ankle is a disaster on image, with the highlight being:
"Severe tibialis posterior tendonitis with longitudinal split tears involving the distal 9.0 cm, moderate grade at the level of the talus and the calcaneus, with mild tenosynovitis. Small spur along the posterior medial tibial metaphysis, at the tibialis posterior tendon groove which can be associated with PTT dysfunction.
"Chronic high-grade anterior talofibular ligament sprain, with at least partial tear. "
I'm told this is the MRI of someone who should be struggling to run on this ankle, but I'm currently doing very well. Running is fine. I did 4 sets of 25 single calf raises on it this morning, no pain. The only issue is that my balance on the right is not as good as on the left.
Right now, the plan is to keep on with the PT, to get an MSK ultrasound to get another look at the posterior tib, and then do another round of PRP on the ATF ligament and possibly the PTT (depending on what the ultrasound says). My PRP doctor thinks surgery would be a really bad idea, and I am really disinclined to even consider surgery when conservative measures seem to be working well right now and I've got pretty good functionality.
But my question to the smart folks here - has anyone else had this type of tear, and had the clinical presentation be so different from the image results? Has anyone else just stuck with conservative measures for a tear like this?
(46 years old and female, if it matters)
Re: Painfree longitudinal tear of posterior tibial tendon. [darkwave] [ In reply to ]
Just curious, what has become of your ankle issue? Are you still running without any problems? Or did you end up getting surgery?
Re: Painfree longitudinal tear of posterior tibial tendon. [EyeRunMD] [ In reply to ]
My MSK ultrasound confirmed that I now essentially have two posterior tibial tendons on my right ankle - one to each side of a bone spur. Both tendons are healthy, with good blood flow. We opted to not touch the posterior tibial tendons at all, and just focus on the ATFL.
We did two rounds of PRP on the ATFL in the fall, and I have been building from there. Lots of daily balance work - I always did 4 minutes of wobble board work daily, but that's now part of about 15-20 minutes of daily ankle strengthening and balance work. If there is a single leg balance exercise, I'm probably doing it.
Right now (knock on wood) I'm training painfree at around 60 miles per week of running. I have a half-marathon this weekend where I'm hoping to run 86-87 minutes - a bit off of my PR of 84 minutes, but I'll take it given where I've been.
The right ankle is still very slightly weaker than the left - daily single calf raises, including some holding a kettlebell, are part of my routine, and the right leg does fatigue before the left. But I can get 25+ unweighted reps on each side, which I understand is good enough to keep me healthy.
Thank you for replying. I'm glad to read you are able to continue running.
I have a longitudinal tear but mine is on the other side of the ankle (peroneal brevis tendon). Also have tenosynovitis. Just like you, I have almost no pain when I run (probably a 1-2 out of 10). After I run, I will get some edema right at the lateral malleolus but it will be gone by the next day. On testing, my ankle is very stable. Based on the good stability and minimal pain, I've elected to not do surgery at this point.
I need to investigate this Mulligan taping you mentioned in your original post.
