I bought a Quarq dfour. I bought the BB. The “q” factor or width or whatever you call it seems right. Tightens up with the preload washer. Sure.
I cannot see for the life of me how my 54t 1x ring will ever fit and not rub the chainstay. There is zero adjustability left to do anything with the crank shaft to work itu that way.
Such a thing as longer chainring bolts and a “pretty” spacer I can use.
Like, with my Rotor round 54t 1x flipped the correct orientation the teeth will hit the chainstay.
Options here? Help?
I had a tiny tiny shim on my old Shimano 5700 crank on the right side to clear it nicely but now I can’t see what to do other than easily needing probably 1/4 inch spacer for the chainring to move outboard.
Thanks!
Options here? Help?
Thanks!
