BB Pros- Need your Help!
Here is what I am dealing with:
2020 QR Five
Press Fit BB Shell in picture, 41mm
Rotor BB30 Ceramic Bearing Set
Shell does not seem to have a groove for the circlips. How do I keep the bearings from being pressed in too far? They did not come with any dust sleeve.
Thoughts?
Re: BB Pros- Need your Help! [Jayjuno] [ In reply to ]
Are you looking at the BB shell or an empty Pressfit30 cup?
A pressfit30 has the bearings already pressed into cups. Those cups are then pressed into the BB shell.
According to everything I've read you don't replace the bearings in a pressfit30 cup.
But...I have done it. It's just difficult to get the bearings out of an aluminum PF30 cup. You then need to prep the cups with primer and locktite.
Re: BB Pros- Need your Help! [jaretj] [ In reply to ]
The photo I sent is a plastic shell in the frame. The stock praxis bearings were a screw type bearing assembly that were press fit into this shell. The bearings I have from Rotor were just bearings, no shell or dust caps.
I don't see any photo.
Your photo did not attach.
I don't know any specifics about the QR bottom bracket type, but a BB shell that measures 41mm is not BB30:
https://wheelsmfg.com/bb-standards
From the limited info you have provided I'm guessing the frame is BB86 not BB30. But I'm sure someone will chime in shortly with specific QR info.
You trying to put these in the frame?
Your QR is PF
Re: BB Pros- Need your Help! [Nelo] [ In reply to ]
My mistake, it is measuring 41.70 mm.
Re: BB Pros- Need your Help! [Clutch Cargo] [ In reply to ]
Yes similar to those. Don’t know why my pic is not attaching.
That’s your problem
You need PF the bearings are in the cups and they get pressed in the the shell
The QR bikes use a PF30 bottom bracket, which is different than a BB30. BB30 is for a 42mm ID bottom bracket shell and the bearing is pressed directly into the BB shell, with circlip installed.
PF30 is a 46mm ID bottom bracket shell; The bearings are set in a plastic or aluminum cup that is then pressed into the BB shell.
This is what you don’t have
Get something with aluminum cups not plastic
Re: BB Pros- Need your Help! [CyclingClyde] [ In reply to ]
Trying my computer to upload the picture. The shell in this picture measures 41.70 mm. I am clearly missing something, but 46mm is not possible.
Trying again with the picture... sorry... just could not get it small enough.
Is what I am seeing an adapter of some kind? The outer dimension is 46.94mm.
I think you're seeing the Pressfit30 cup
I have a 2019 QR PRFive and it uses a PF30 (46mm ID BB shell). I bought and installed this BB: https://mybikeshop.com/...bracket-68-92mm.html. It is possible they changed their BB standard for the 2020 model. Unfortunately Quintana Roo doesn't list this BB standard information on their website. You could ask the people at Mybikeshop.com on their web chat. They are very responsive and sell a lot of QR's.
Re: BB Pros- Need your Help! [jimatbeyond] [ In reply to ]
Thank you for this, but what I am struggling with is the plastic shell that is inside the frame after the Praxis M30 bearing set which had a screw together shell was removed. I finally got a picture uploaded a few strings above. It is a single piece and it has an ID of ~41.8 mm, not 46mm that everyone thinks it should be.
It appears adhered to the frame and not to be pushed out. A set of BB30 bearings easily can be pressed into this shell, but it does not have stops and I can’t tell exactly where they should sit.
The black part is the Delrin PF sleeve from the Praxis BB. Shown as #4 here: https://praxiscycles.com/...30.BB-PF30.REVB_.pdf
It is supposed to go in with grease. Have you tried tapping it out using a punch against one of the holes in the sleeve? I can’t think of any glue that would stick solidly to Delrin. Maybe it was installed with Loctite bearing retainer fluid which essentially is a void filler. Maybe a little heat from hair dryer or heat gun if it doesn’t just tap out?
Re: BB Pros- Need your Help! [SummitAK] [ In reply to ]
Those can be pretty tight. We were using Praxis BBs a few years back, and it usually took a bit of effort to get those sleeves out. A punch in one of the holes will work, I usually used a Park RT-2 headset remover. Once you get one end out about 1/2", past the raised end section, you could usually just pull it out by hand...
"I'm thinking of a number between 1 and 10, and I don't know why!"
Bingo! That is it! Thank you very much. Would have never found it based on the name of that thing!
I haven’t tried tapping it out but will give it a shot. Now I see how I get to PF with ID 46.
Thank you all for bearing with me!!
