I've done a lot of research and I can't seem to find the answer and Rouvy support has not been much help either. Basically, I have Kreitler rollers and new Garmin speed and cadence sensors. I'm selecting generic bluetooth connection as the trainer and my sensors are being recognized. When I go to save, the sensors are there, but no trainer is being saved. I've tried a few other "dumb" trainer selections like fluid and mag trainers that are in their compatible list of trainers, but the same thing happens. Since those trainers do not send a signal I thought it would save easily because no connection needs to be made.
Do I need to connect with an ANT+ sensor instead of bluetooth. I'm using a windows 10 pro machine with bluetooth 4.2 which should be fine with connecting. That machine is also recognizing the two sensors as available bluetooth devices. I'm trying to get an idea if this will work before I throw more money at a ANT+ sensor since I'm obviously trying to keep this cheap. If not, it seems like Zwift might be able to accommodate this setup. It just seemed like Rouvy was able to do something similar as long as you had a speed and cadence sensor.
Thank you in advance for any help you can provide and Happy New Year
Barry
Great things never come from comfort zones.
Barry
