Eroc43 wrote:
I used to live in Houston and I think the answer is.... Kind of.
I think it will be very hard to keep the actual temp at 73 in the summer. Unless you want to spend a good deal on an AC bill. Also you would be cooling it 24 hours a day, to use it for a limited amount of time. (I don't think a portable would cool it fast enough and might struggle to do so at all)
I think what you really need to be after is airflow. My paincave is poorly insulated in Seattle and I will sweat my ass off when the room temp is 39 degrees.
I think if you black out the windows, and get 3 good fans (2 front and 1 behind) you can have a good spot. Plus in the words of a great movie...SO MUCH ROOM FOR ACTIVITIES!
Also heat training is supposed to help simulate altitude training, so you would have that as a benefit.
You don’t want to “heat train” at the expense of a quality workout. If the body is working too hard to cool itself, then your muscles won’t be able to perform what you want them to, and you will not get the muscular adaptation the workout is designed for. Your workouts should be cool and comfortable, and if you want to heat train, go and sit in a sauna after. Same thing with altitude training. Train low altitude, live/sleep high altitude.
