I have just begun training with a HR monitor since the end of December. I have done two step tests on my trainer in order to determine my LT. Both tests turned out well, clearly revealing my cycling LTHR was around 183 - 185 bpm. Also, the second test was shifted slightly, indicating I had better performance at a given HR.
So now I want to do some zone 2 work. According to Friel this is 152 - 165 bpm or so. I get on my bike and start warming up, easy at first and progressively harder, however, not too hard to induce any leg burning or heavy breathing. I usually notice an overshoot here, in otherwords I go a bit too hard so that if I continue at the current intensity I would be in zone 3, at this point I back off slightly (as my HR reaches 165). What I find however is that after some time at the current intensity I have to back off in order to keep my HR under my specified zone, and continue to back off until I finish my goal workout time. I presume that as the workout continues, my elevated HR is due to cardiac drift and/or fatigue. I've heard about cardiac drift, but I don't really know what it is exactly and how pertains to the above situation.
Do I need to try to stay in zone 2, or does zone 2 shift due to cardiac drift? If zone 2 is indeed shifting to a slightly higher HR, how much can be expected?
As a side note, I understand that the numbers 152 - 165 are not set in stone and that I need to use P.E. as a second indicator, but I have found that these numbers are in line with the corresponding R.P.E.
Thanks
"What the mind can conceive and believe, the mind and body can achieve; and those who stay will be champions."
Thanks
