TH3_FRB wrote:
Ultegra 8070 hydraulic calipers with Ultegra R800 rotors.
so I went to read the user manual for these, it says,
https://si.shimano.com/...8VR0A-005-00-ENG.pdf Disc brakes have a burn-in period, and the braking force will gradually increase as the burn-in period progresses. Make sure that you are aware of any such increases in braking force when using the brakes during the burn-in period. The same thing will happen when the brake pads or disc brake rotor are replaced.
So the manufacturer doesn't recommend bedding in the disc brakes. But everyone you ask (as witness this thread) will tell you it's necessary to bed in disc brakes.
I was told the reason my discs were squealing, was due to my neglect of the bedding-in process. Due to that neglect it was now necessary to remove the pads, sand them down, clean with alcohol and clean the rotor similarly, then do the bedding-in.
So far I've found no manufacturer or other documentation that mentions this, or exactly what the bedding-in protocol should be. It seems to be one of the things that all disc brake riders know, but where they learnt it isn't obvious..
one of the many reasons I prefer rim brakes ;-)
