I've a Propel that would need the brake change for 25mm tires.
I came across the Surly Monkey Nuts. Essentially a dropout spacer that gives you 5mm. Surely there's 5mm of room in the dropouts and should be enough up/down adjustment in the brake shoe area to make it work.
Anyone done this on any of your bikes to achieve some tire clearance with success? I wouldn't need to worry about any quick changes from using them, I ain't racing anything where there's fast neutral service changes. Just my lonesome on the side of the road if I get a flat to change.
https://www.worldwidecyclery.com/...KEAQYAyABEgJR1_D_BwE
