I am building a SRAM Force 1x Setup for my Road/Gravel/Cross bike. I want to add a power meter that is not pedal based or hub based, as I will most likely use mountain bike pedals and rotate wheels depending on conditions.
Is the Quarq DZero Crank, the best setup? Are there other worthy options?
https://www.quarq.com/product/quarq-dzero-carbon-power-meter-chassis/
I appreciate the help.
I would suggest a power2max ng eco.
Works rock solid!
Awesome!!!! Fits the SRAM force cranks.... no need to get the Red or Quarq cranks
any quarq will work. if you already have a sram force crank you will just need the quarq spider in either 110 or 130 bcd.
What BB is your bike? I was going to get another Power2Max for my Exploro but learned you can’t use P2M with SRAM cranks on a BB386 frame. I’d work fine with a Rotor crank but I already had a SRAM Red 8 bolt crank and didn’t want the added expense of switching cranks on top of buying a power meter so I bought a Quarq Dzero. I’ve got about 1k miles on it and so far It works great
Tifosi01: Mar 24, 19 13:32
