I Googled this and came up with a "you can't dothat" type answer. However, nothing is impossible if you want it bad enough and this group is pretty cleaver in their thinking, so...
I have a Nest Secure System. I bought a Detect sensor for the garage door. It is a standard sensor/magnet type device, just a little cuter with a few extra features. The instructions say it can not be put in an environment below 40 or above 100. My garage is attached but unheated. It will probably exceed both of those temps for some of the year. Nest groups says that the limit is for the battery life and all that happens in harsh environments is the battery goes dead quicker. It doesn't affect the sensor functions. That is not a problem, I can live with that.
The problem is how to attach it to the door so that it will function as an open/shut indicator. I can't figure out a way to do that. It also will function as a sonar sensor if I put it on the wall, but the motion detection function on Nest only works in away mode, and only all of nothing. That makes it impractical to use because when we are at home and asleep the motion detectors are off - the most likely time someone would break into the garage.
So what I'm looking for is an innovative solution to sensing garage door movement.
One last thing, there is no electric opener on the door. I realized that is a solution but I'm not ready to take that on quite yet.
I'm counting on all you very cleaver thinkers to get me going the right direction. Thanks in advance.
"...the street finds its own uses for things"
