Alvin Tostig wrote:
Hmmm, I'm not familiar with "soft start" bulbs. Are they some of the new fangled energy saving (LED or fluorescent) bulbs?
Back in the day, when everything was an incandescent bulb with an honest to goodness wire filament, bulbs would tend to blow out when they were first turned on. The resistivity of tungsten (or any other metal) is less at lower temperatures. From Ohm's law (V=IR), you would get more current flowing until the filament warmed up and its resistance increased. Too much current and the filament would melt/break, and the bulb would be burned out. If you could make an incandescent bulb that would slowly
decrease the resistance after the bulb was turned on, the initial current would be less, making the brightness less (P=IV). Higher initial resistance (but a dimmer initial light bulb) would have been an advantage as far making it less likely to have the bulb burn out.
But who uses incandescent lightbulbs these days?
Bravo!
Just one more thing to add...
Also back in the day, there were 3-way bulbs that had a low-resistance (high brightness) filament and a high-resistance (low brightness) filament. The switch would cycle 00, 01, 10, 11 to give off, low, medium, and high brightnesses respectively. But, this caused a lot of start up cycling for the high-resistance filament and would burn them out prematurely.
A clever solution to this problem was to have the switch operate in a Gray Binary sequence of 00, 01, 11, 10 or off, low, bright, medium. But it never caught on commercially.
[Sorry. I got my geek set on high today.]
"100% of the people who confuse correlation and causation end up dying."
