Not sure if you had a chance to look/listen at the podcast with TrainerRoad and Specialized....
https://www.youtube.com/watch?v=yf6FwjoZ0tE
The discussion about skinsuit was pretty interesting... apparently the difference between a skinsuit that is just tight and smooth and their new skinsuit could be up to 20 watts... something to do with texture material that break the surface tension. (pretty sure the 20 watts was only in some specific cases... but i will be happy with half of that)
From what i understand, when it come to aero, we are all different.... we will get different gain from different changes, etc.
That been say, based on the podcast above, smooth race texture are generally slow.... and texture material is alot faster.
I'm just wandering if someone had a chance to test different racesuit that are claiming some form aero optimization??? is there a big difference between all of them ???
While i could get away with testing position, helmets, and maybe wheels (borrow from friends)... There are no way i could test multiple kits (i will be lucky if the one i order fit)
