RChung wrote:
Typically you can if you calculate the VE profile.
(As an aside, this is the problem I was trying to solve when I came up with VE 16 years ago. I had power, speed, cadence, HR, but I wanted to identify laps).
The VE profile (look at the pink chart in the attached image) basically reflects the speed profile, i.e. if one sees the curves in the VE profile one should see them also in the speed profile (from a wheel speed sensor).
The VE profile based on the speed from a wheel sensor overestimates the altitude fluctuations of the centre of gravity (compare pink chart with blue chart in the attached image).
(In the sample of the attached image is from a 11 rounds run on a 200m track with a curve radius of 17.75m. Power data from a SRM PM and speed from a wheel speed sensor are “original” i.e. unfiltered as they come from the ANT+ streams. Power and speed data are synchronized to each other roughly ~0.2sec. And both are synchronized to lap times or a lap marker respectively.)
