https://bikerumor.com/...ficial-intelligence/
...the Ai part doesn't interest me that much. I found this section rather interesting:
I find it interesting that the "Ai" ended up using the maximum width available to it.
Quote:
Smith’s AI optimization routine was first programmed to find the lowest drag cross section possible that would work with a 25mm tire. They constrained the depth to a maximum of 77mm and let it fly. The initial result was a rim that measured 42mm at its widest point, so they added a width constraint of 30mm so it would fit in traditional bicycle frames and forks.I find it interesting that the "Ai" ended up using the maximum width available to it.
Quote:
Specs for the new rims and wheels are: - Width at brake track: 29mm
- Maximum width: 30mm
- Depth: 77mm
- Weight: 625mm per rim
- Clincher wheelset: Venn Var 77 TCC weight: 1894g
- Disc brake wheelset: Venn Var 77 TCD weight: 1915g
