rock wrote:
The body will only convert protein to fat an store it if it's in an extreme caloric surplus. The purpose for consuming approx 1g/lb while cutting is not for muscle building, it's for muscle retention. You need less protein when trying to build muscle if you're in a caloric surplus.
Hence why my main point was to start tracking to set a baseline. Then to cut set your protein at 1g/lb as a starting point, and set fats/carbs at 250cal less than maintenance. That is the optimum approach to maintain muscle mass while slowly and sustainably shedding fat.
If you are building muscle wouldn't it stand to reason that you need more protein, not less?
1g/lb: as I said before, short term excess protein as it is traded for Carbohydrates (which retains water) during cutting helps you shed water, not fat, due to reduced CHO storage, and reducing your overall weight in the process. Long term if the total calories is less than your need, yea, no kidding you'll burn fat.
The OP from what I can tell has no need to do any of that.
Let me be clear: There is no doubt that increased protein levels help increase and preserve muscle mass. I'm not even saying that it'll make you fat. Excess overall calories do that, and protein can be a part of that equation whether we like it or not.
There's a weight gain study that many websites plug to claim we don't convert protein to fat, only to plug their no-doubt proprietary protein supplements and store: the study shows a higher protein diet had higher weight gain, but higher muscle composition and all gained the same fat mass. It also shows in their statistics that increased protein levels predict lean muscle mass gain but not weight gain, only excess calories predict fat mass storage. They also found that to preserve muscle, the 15% group was adequate (100 ish grams per day), also some major trade offs for increased metabolism, blah blah blah... Show that increased protein (15 - 25% daily intake) is good for lean muscle, yes. If anything it even showed that we can eat more calories in general if our overall protein is higher, due to increased metabolism. Prove that we don't turn protein into fat on a daily basis if we overeat? NO.
As an exercise physiologist and human anatomy teacher I can tell you: our metabolic systems, cycles, processes, are always active, they shift up and down as we consume, whether over or under. We can consume and use A LOT of protein, depending on how we train. In extreme circumstances we can break down muscle fast and use as energy, when our CHO and/or fat stores get low. The protein absorbed that we don't use during overall excess consumption (no matter how little) gets converted to other useable macronutrients. If it doesn't get used either by protein synth or energy, it will become stored fat. Period. Thats the hallmark of our adaptability.
In the end, your muscles will still only use what they can use and need. If its 2.2g/kg, then great. Realistically, most recreational athletes just don't need that much, and are better off dialing enough protein (framework) to boost training, then focusing on having the right micronutrients (nuts and bolts) from fat and CHO intake for the rest of the balanced diet.
Matt Leu, M.S. Kinesiology
San Pedro Fit Works, Los Angeles, CA
Endurance Athlete and Coach
Consistency/time=results
