GreenPlease wrote:
but you should know that Compass’ compound is inferior. Check out how their new “road race” tire stacks up against the usual suspects in that category (same compound used in all their other tires fyi).
Are you talking about the bicyclerollingresistance test of Panaracer's Race A Evo 3? I was actually surprised how well that tire scored, considering what Panaracer's protection layers are like.
Tom A. wrote:
Going narrower on tires for the more pavement oriented rides doesn't really gain you much speed, but adds to the discomfort over the rougher sections. By contrast, a smooth treaded, wide tire will have you traveling just as fast on pavement as a narrower tire, but will be way more capable off road, mostly due to the extra "suspension" and lower tire pressures allowable.
Ironically, when I ride my Rat Trap Pass ELs on mixed-surface rides, I notice the biggest advantage on paved sections.
When people err narrow, they need to run more extreme drop to get the tire well-behaved enough to ride the rough stuff, and then they need sidewall protection so that resulting high sidewall exposure doesn't result in cuts... you can end up with a tire that rolls quite poorly. On mountainous double-track that's not always noticeable because speeds are limited by trying to not die, but on the smooth road, efficiency is bared.
