Slowman wrote:
so, when you talk about opening your hips, etc., yes, but what tom and i are talking about is whether you can retrofit a road bike to duplicate your tri position exactly. and, yes. you can. but most of our ass-over-teakettle crashes stopped taking place once we moved to bikes made for the position, and there is one thing i've always wondered which tom can help with: what happens to Crr when you add an extra 20lb to the wheel? and i don't mean the drive wheel, but, what happens when you add payload to the wheelbarrow. i'd like to see the results of that test.Since by definition the Crr is the ratio of retarding force to wheel load, the Crr of each tire is unchanged. However, the retarding force attributable to the front wheel is increased by Crr (front tire) x 20lb...then again, the rear wheel retarding force is reduced by Crr (rear tire) x 20lbs. If one is running the same tires front and rear, then it all "comes out in the wash", and the total retarding force attributable to both wheels together is basically unchanged.
In fact, if one is running the same Crr tires front and rear, then one can estimate the total retarding force by just multiplying the Crr by the total bike+ rider weight. The distribution of retarding forces front and rear will be proportional to the weight distribution percentages.
