Just chiming in as I have the Syncro setup on my TT and I'd say Im pretty happy with it.
The one thing that i haven't seen anyone mention yet - but in the ETube settings there are a few options that may help you solve this issue: There is a "shift speed" setting that I think its set to "NORMAL" as default. Upgrade this to "FAST". and second is the ability to hold the button down to shift up or down unlimited gears - enable this.
In the example given, I personally don't even have get out of my aero position and all I do is hold down my single button shifter the moment i start feeling the big ring is too much and it shifts down all the way to the small ring in a flash. This also works the other way around when i get to the top of the hill and want to get on the big ring ASAP, it just smashes through to the other side.
One more thing - you have the flexibility of setting your gear ratios too. So if you feel that in this "flash shift" you end up in too small of a gear once you hit the small ring, you can change it so the change is to your liking (bigger or smaller ratio).
I've never tried ETap before, but i did a ton of research and based on durability, battery life, shift smoothness, etc I ended up picking Shimano Di2 instead.
Hope this helps
3toronto Triathlon
Hope this helps
3toronto Triathlon
