hiro11 wrote:
One word of caution: if you need a complete bike, get a complete bike. If you're buying everything retail, once you add up the frame + componnents + wheels + cables + tires etc, you'll find that you don't save much with an open mold frame vs. just going to a bike shop.
Yes and no.
I'll give a run down of a hypothetical build using my $375 Flyxii frame:
Frame, fork, headset, seatpost: $375
105 5800 groupset: $425 (Merlin) - comes with cables too
Campagnolo Khamsin wheelset: $150
Vittoria Rubino Pro 3 x2 tire: $30 Tubes: $5 Deda Road Stem: $15
FSA Handlebars: $25 That's about $1025, not including saddle or pedals (personal choice for any bike you buy anyways.
Let's look at Nashbar's $1000 bike - FSA Crankset (where my size, 50CM would come with a too long of a crank arm), bottom barrel brakeset, cheap 26TPI tires, carbon fork with alloy steerer (vs full carbon), lower end wheels.
Bikes Direct is similar to Nashbar, but $100-150 more for full carbon.
Performance has a Fuji for $1350 (plus tax, so closer to $1425), but with cash back in performance points, you're close to that $1k mark. Oval concepts crank, wheels and brakes though. And you'd need to spend that $400 in extras.
I guess what I'm getting at is that you can find a handful of lower-end carbon bike retail for not much more. But then you're stuck with what you've got. I can't specify a 170mm crankset without replacing it. If the stock brakes suck, it's $60 to get 105 ones. If you want a $400 wheelset from the start, put that $150 for the basic wheels I had and put it toward the better wheels. More importantly, you do get a larger choice of frame geometries going with Chinese carbon. I'm not limited to 1 or 2 models.
