Hi ST,
I am converting my Road-Cockpit to Tri and have zero experience or even knowledge of Aero Brake-Levers. The front-brake is an Omega-X and the rear is some Tektro at the bottom bracket. I currently run both brakes without adjuster (eTap Road-Shifters). That works well, but I need a bit of cable-pull because the rims (24mm Mavic Exalith) are a bit smaller than the tires (GP 4000II 23mm front, 25mm rear).
Future basebar will most likely be Stratis CX basebar (20,5mm internal diameter) with eTap Blips. After gathering some information I plan to play it safe an use SRAM 990s. However, before I mess things up and end up offroad could you give me your advise?
Thanks, Tobias
Thanks, Tobias
