I don't run this anymore, but I used to run a 2-rear cage metal setup on a behind-the-seat Xlab. I chose metal after having repeated launches with plastic cages.
I guarantee that those metal cages were wayyyyy tighter than any of your fancy $70 cages after I had bent them into the 'locked' position on my rides. You couldn't hpull the bottle out riding even if it were mounted between your legs. (I had to stop and use TWO hands to force the things out AFTER bending the metal cage back some, and it was never easy!)
I somehow could manage to STILL eject a bottles regularly on long 70-90 mile training rides when hitting lots of bumps with these crazy tight metal cages. There's something about that behind-the-seat setup with repeated hits or something that I suspect deforms the bottles (I used Camelbak bottles) enough that they'd eventually squeeze through even super tight cages.
I even duct-taped the bottles for 'grip', and they still ejected. The only thing that stopped it finally was to put ugly rubber bands encircling the entire cage+bottle setup but that was fugly.
It got annoying enough that I just ditched the behind-the-seat setup and now run a BTA bottle and a tube between the legs. Those never eject, even with cheap plastic cages. I think the position of the bottles makes a difference, with bottles behind the seat being at much higher ejection risk.
For me, the cage made zero difference. The position made all the difference.
