I see that the 1030 has WiFi but I'm having a hard time ascertaining whether it can sync directly to Garmin Connect when connected to WiFi, and not needing to sync via your phone.
Re: Can an Edge 1030 sync directly to GC over WiFi without going through your phone? [JClishe]
JClishe wrote:
I see that the 1030 has WiFi but I'm having a hard time ascertaining whether it can sync directly to Garmin Connect when connected to WiFi, and not needing to sync via your phone.my 1000 can do it, you need to enable personal hotspot on iphone.
Re: Can an Edge 1030 sync directly to GC over WiFi without going through your phone? [sebo2000]
sebo2000 wrote:
That sucks. Might as well sync the old school way through BT.
My 1000 syncs directly to wifi, no phone needed. Assume the 1030 does the same, can't imagine they've gone backwards.
Re: Can an Edge 1030 sync directly to GC over WiFi without going through your phone? [cartsman]
cartsman wrote:
My 1000 syncs directly to wifi, no phone needed. Assume the 1030 does the same, can't imagine they've gone backwards.That would certainly be ideal. I'll be upgrading from an 810 so this will be new either way, but only being able to connect to a personal hotspot wouldn't be very valuable.
From the perspective of the Edge, a personal hot spot is just a wifi connection, no different to any other. If it can sync on a hot spot it can sync via any wifi with an Internet connection. I don't think mine can handle hotel type wifis where a separate login screen pops up on your browser, but any home type wifi with simply a name and password should be fine.
https://www.dcrainmaker.com/product-comparison-calculator?type=watch&ids=30244%2C79101#results
DATA TRANSFERUSB, BLUETOOTH, WIFI
You are good to go.
You are good to go.
JClishe wrote:
by saying via personal hotspot it means any wi-fi you have password for. No phone needed, at home I sync via my home wi-fi out on the road via phone personal hotspot (wi-fi)
