Rear hydration Cervelo P3
I'm looking for a race day rear hydration setup for my 2014 Cervelo P3. I see Xlab has the sonic which fits specifically in the P3 seatpost. Any reason this is 3 times more expensive than the Delta 105? Why can't i just use that?
Do i need anything fancy if i just want to be able to carry one bottle back there?
Thanks!
Re: Rear hydration Cervelo P3 [IanH] [ In reply to ]
Sonic is if you want to run 2 bottle cages, delta is only 1
Hi IanH
You can definitely use the Delta 105 if that is more in line with the budget.
The cost variance is in the material difference and where they are made (labor costs).
Delta 105 - composite mount, composite cage. Mount is made in Asia.
Delta Sonic - carbon fiber cage, stainless steel mount which is individually bent and made in the USA.
If you go with the Delta 105, you will notice a bit more movement in the mount and the Xenon cage won't grip as tight as the Gorilla, but should hold a decent amount of bottles.
As far as naming, we called our Cervelo-specific carriers 'Sonic' - so we have dual Sonic carriers and single Sonic carriers. Couple to a few years after they were developed other bike manufacturers starting using same mounting methods. So although the name meaning is no longer valid, we kept it as it goes with our aerospace background!
Candice Turner
CEO
XLAB - Aerodynamic Triathlon Accessories
Dawn to Dusk - Off-road Specific Storage Accessories
http://www.XLAB-USA.com http://www.dawntodusk.bike
Re: Rear hydration Cervelo P3 [Candice - XLAB] [ In reply to ]
FYI - I went with the Delta Sonic ML and despite it costing more than i was hoping to spend, i'm very happy with it. Easy to install, easy to use and seems very durable. Hoping it lasts a long time!
Thanks for your help.
Glad to hear it worked out!!
Candice Turner
CEO
