413,893 offenses in Australia in 16-17. I couldn't find violent offense or resisting arrest numbers because analysis shows that police shootings are far more likely as you narrow the band to violent offenders, and then again to people who refuse to cooperate with the cops.
http://www.abs.gov.au/...01BD477?Opendocument Anywhoo, 10,797,088 arrests in the US in 2015.
http://www.drugwarfacts.org/node/235 I'm not sure this is apples to apples because one is
offenders and the other is
arrests, there may be a not-insignificant differentiation there (which, if you think about it an arrest is more likely to result in a violent outcome than an offense that may or may not result in arrest), but I don't have time to look into that. Also, I'm using
this WP data of US police fatal police shootings, basically just under 1,000 a year in 2015, 2016 and 2017--so the stats are even padded in your favor here).
So the final numbers (drumroll please....)
6 fatal police shootings among 413,893 offenses is a rate of 1.4496 per 100,000 offenses
1,000 fatal police shootings among 10,797,088 arrests is a rate of 9.2617 per 100,000 arrests
So the US rate is 6.3x as high in the US. Are people in the US more likely to have a gun on their person and engage the police? I think if you were to further break down the numbers to see arrests of armed individuals you'd see an even bigger gap in overall numbers, leading to closer fatality rates.
I'm not arguing for or against guns just presenting some facts. I think the size of this country and the criminality of it is often overlooked in these conversations. 6 vs 1,000 is a HUGE difference, but 1.44 per 100,000 vs 9.26 per 100,000 doesn't seem quite as bad and I think if you further unpack the data it'd be even closer.
