Re: What's the current IM Florida water temp? [Spindogg]
As of Saturday, water was in the 79-82F range.
Fall is finally here, and from here on out, we get daytime air highs of around 80F and overnight lows in the mid 60s along the coast. My guess for race day would be 74-75F
Re: What's the current IM Florida water temp? [FLA Jill]
Re: What's the current IM Florida water temp? [HotBeansNButter]
Is there an official wetsuit policy regarding the use or non-use of wetsuits that WTC abide too?
it will.....
I shall never misuse Rex Kwon Do
I shall be a champion of freedom and justice
Re: What's the current IM Florida water temp? [Bladed]
Though if it's at all close, they'll probably manage to find an official 77F reading somewhere along the beach.
Which is an interesting contrast to the fall season locals races down here where someone will ask the RD what the water temperature is, and he'll respond "toasty"
Re: What's the current IM Florida water temp? [Jonas]
Are you bringing the Sweedish Bikini Team with you, if so then the water temp will be 80f and Ill draft off your team, hehehehehehehe
_____________________________________________
I have horrible back problems but I have zero problems staying in an aero position for 180k. Why? Because I ride steep and because I train regularly in that position. Simple as that.....Gerard
As far as I know it is the same as USAT.
78F and a wetsuit is not a good combo....too warm. I hope the temps take a real dive or stay above 78F.
Also of note.. the race site shows 2800 people registered. Wonder how many will be out on race day? I couldn't get a response from the race director on whether or not they actually have a ceiling on allowable numbers (I was curious). The bike course is a single loop so they can get by with more folks on the course than multiple loop folks but there has to be a limit in someone's mind.
I suspect that has to mean IMFL is the top grossing race of all M.dot races $1,190,000 in entry fees not counting the ones that bailed out already and paid partial entry fees. It also sells out very quickly. Got a good thing going there.
HotBeansNButter: Oct 13, 05 18:50
I believe the rule is the same as the USAT, 78 or below.
But you can wear a wetsuit regardless, you just become ineligible for awards.
Re: What's the current IM Florida water temp? [astrotri]
Current temp is 72 degrees!!!! Perfect temp. From the NDBC website listed above...
http://www.mountainmettle.com
Hurricane Wilma and a strong noth wind has stirred up the gulf and messed up the weather in florida. today's paper shows the water temp off tampa as 64F. NOAA shows PCB at about 73F. things should get back to normal by the weekend but i doubt the water temp will be over 78 on race morning. the evening temps are going to be in the 60s, the days might hit 80.
"Competetive sport begins where healthy sport ends"
GTG changed their rules, so it's not the same as USAT. No wetsuits at all above 78 degrees. That having been said, if it's borderline, I'd bet they'll try their best to find a spot that's at 78.
Re: What's the current IM Florida water temp? [Peanut]
The last three mornings here in the Panhandle we have had temps in the mid-low 40s. That should cool the water some. I had frost on my car this morning.
Re: What's the current IM Florida water temp? [tri_bri2]
I was going to bring a full suit and a sleeveless. I prefer to swim in the sleeveless. Think I'll be ok leaving the full at home?
Thanks!
Andy
'You'd be surprised how many people violate this simple principle every day of their lives and try to fit square pegs into round holes, ignoring the clear reality that Thinsg Are As They Are.'
Thanks!
Andy
78 to 79 degrees as of noon 10/26.
Unless it breaks into the 60's, I'm going sleeveless.
Re: What's the current IM Florida water temp? [bshanberg]
Where did you get those numbers? The noaa site has it listed as 73.8 degrees at 1pm eastern today.
Damn, below 75 would be PERFECT! Let's hope it stays like this for another 10 days!!
-C
Any run that doesn't include pooping in someone's front yard is a win.
-C
Re: What's the current IM Florida water temp? [CCF]
http://iwin.nws.noaa.gov/iwin/main.html
Had to drill down quite a bit to find Panama City Beach.
That noaa site is fine for getting a rough idea of PCB temperatures, but if one is planning to do IMFL, it's better to use the official water-temperature gauge that will be used for the race, as seen here:
http://www.trinewbies.com/...47451253#M2147451253
Two roads diverged in a wood, and I--
I took the one less traveled by,
Which is probably why I was registering 59.67mi as I rolled into T2.
Surfline has the water about 71-73 right now.
http://www.surfline.com/...fm?alias=panamaflcam
Jeff
#1194
MARTY: Let’s talk about your reviews a little bit. Regarding ‘Intravenus de Milo’: “This tasteless cover is a good
indication of the lack of musical invention within. The musical growth rate of this band cannot even be
charted. They are treading water in a sea of retarded sexuality and bad poetry.”
NIGEL: That’s, that’s nit-picking, isn’t it?
Jeff
#1194
