"You're guaranteed to miss 100% of the shots you never take" - Wayne Gretzky
Re: Reid is much steeper than Macca..... [flytri]
Sorry guys, I have been trying to post the picture of Reid and Macca in the bottom left hand corner...
http://www.triathletemag.com/...amp;publicationID=92
Interesting contrast in styles. Macca looks "big slammed" slide well back on his seat. Reid is on a 76 degree custom frame from what I understand, but is well forward on the seat probably putting him 78 degrees or better.
Re: Reid is much steeper than Macca..... [Pooks]
Time for class…
This first time you tried to paste the link you copied it to your local drive and put up a link to that - as your PC is not a web server that just will not work…
…http://c:/Documents%20and%20Settings/iseliw/My%20Documents/My%20Pictures/macca_reid.jpg…
The second time you had it – however you need to make sure that you do not double up on the http header as you had done….
…http://http://www.triathletemag.com/gallery.cfm?gallery_id=136&pageID=1735&publicationID…
What you want to paste in the image box is just the URL that you can get off the image or from the "view source" HTML
…http://66.77.216.76/...mages/macca_reid.JPG…
Post deleted by Administrator
Re: Reid is much steeper than Macca..... [LarryCalifornia]
Thanks guys :-)
Oh great! Now macca doesn't know how to set up his bike. I guess he just can't do anything right. Why don't you Americans just leave him alone?
customerjon @gmail.com is where information happens.
Re: Reid is much steeper than Macca..... [customerjon]
Relax pal, I was just showing the difference in angles that the two ride. It sounds like you are defensive for some other reason. I cant help you with that....
Sorry. Forgot to put ;). I was just playing. Everyone got so uptight about Macca brilliant Kona performances I just wanted to be a dick.
No problem, I understand... I like to be one from time to time also....
Cheers....
Cheers....
