I am upgrading from DA8 to DA10. Do I need a new rear hub?
Re: Q for bike techs [elund]
Only if you want to put a ten speed cassette cluster on the rear wheel.
http://www.sheldonbrown.com/dura-ace.html
To avoid this problem, Shimano has made the first change in their spline pattern since the introduction of Hyperglide in the late '80s. Dura-Ace 10 freehubs have taller splines than other Shimano models. As a result, it is not possible to install cassettes other than 10-speed models on Dura-Ace 7800 hubs. It is not, however necessary to use Dura-Ace 10 speed cassettes. The Ultegra 10 speed cassettes also accommodate the taller splines of the 7800 hu
That article answered your question ;
'The 10-speed cassettes will fit on any Shimano 8- or 9-speed Freehub with no problems.' Although I believe there is a spacer you require.
10sp cassettes work fine on all 8 or 9 sp Hyperglide freehubs, just need a 10sp cassette, it includes the spacer for 8/9 hubs
Doh. I am illiterate.
