Special Front Deraileur For Compacts?
Hi
I just saw an ad for a front derailleur from IRD which is made specifically for compact cranks...
After hearing about the new campy compact group with its special front derailleur specific for compacts I was wondering if there is a noticable advantage...
Wasn't aware that such a product existed for shimano components
thanks
Re: Special Front Deraileur For Compacts? [taku] [ In reply to ]
Currently Shimano does not make anything compact road (i.e. cranks, deraillers etc) so if you're running shimano and want to say use FSA compact cranks you have 2 choices
1. you can use a standard derailleur however the shifting wont be as good because of the bigger jump in chainring size (53-39 = 14) versus (50-34 = 16) plus the curvature of the derailleur is set up for larger diameter chainrings.
2. you can use a compact specific front derailleur - such as the one from IRD (about $80 canadian) and I believe FSA is coming out with one as well. you could also try running a campy one - but I dont know if you can mix campy front derailleurs with shimano shifters
Campy has come out with compact cranks albeit in uber expensive carbon only as well as a full range of compact front derailleurs starting at the centaur level and moving up to record...I've been having trouble acquiring a front right now...but until a few weeks ago they were pretty widely available...
As for the difference in shift quality - I dont know since I dont have one yet...but others on the board have commented postively...
so in summary use compact front derailleurs if you're using compact cranks...
Re: Special Front Deraileur For Compacts? [Jekyll] [ In reply to ]
You can run ANY Front Der with ANY shift lever...I dont care if it is a 20 year old Nuovo Record or Superbe Pro with a ShitmaNO lever...they are all compatible.
I'm running an older DA 9 speed front d. over Ritchey compact cranks and can honestly say I have had 0 issues shifting. I have yet to drop a chain or miss a shift evn running 50-34.
