From a new puzzle book by Serhiy Grabarchuk, entitled The New Puzzle Classics: Put ten dots on a piece of paper, in the form of a ten-pip domino. This will look the same as a pair of dice with fives on them, side by side. You can number the top row of dots one to four... the two middle dots five and six... and the bottom row of dots seven to ten. The object is to draw a closed loop of four consecutive straight lines, going through each of the dots once. So draw a straight line... from the end of that, draw another straight line... from the end of that draw a third straight line... and from the end of that draw one more straight line that returns to your starting point. Every dot must be crossed once. Can you do it? Your solution should give the number of the dots in each of your four lines.
"Go yell at an M&M"
"Go yell at an M&M"
