FTD wrote:
My two cents.
1) Appropriate strengthening in pain free ranges
2) Light stretching, not aggressive, your neck needs mobility but stability is certainly more important. See Charlie Weingroff for more on this.
3) Try a home traction unit, over the door type. They work very well for decreasing local and radicular symptoms. 4) Myofascial massage is often effective to relive acute symptoms and cervicogenic headaches if present.
You've gotten a lot of good advice, and I had the same problem though higher up, and serious pain radiating down my arm.
The above 4 points gel exactly with my experience. Additionally, I had chiropractic done by someone with outstanding credentials, referrals by endurance athletes, and who is a lifelong distance runner (at that point, I had nothing to lose).
Home traction did me a world of good. If you're a cheap bastard like I am, you can even build your own. Essentially, with all these modalities, the idea is to take enough pressure off the disc (keeping surrounding musculature well, lengthening the spinal column, etc) to relieve the pain and allow the body to heal itself as much as possible.
Ice worked well to relieve pain and inflammation, as well.
Over the course of four weeks, I managed to get back into training where I'd left off, but it was a solid four-week break. I still have symptoms crop up now and again (it's been years), but I go back to the home traction, stretching, ice if need be, etc. and usually get resolution in a few days without needing to adjust training.
Yanti Ardie of Y Tri Multisport & Majick Juice for lasting critter defense & skin soothing
~ World Open Water Swimming Association Coach & Official
~ IRONMAN Certified Coach (Founding Member)
~ Triathlon Australia Professional Development Coach
~ 3 by the Sea: my Journey from death to ...
