I use LeWedges, and highly reccomend them to most riders (based on need)
Re: Please comment on my aero position - UCI legal [AndyPants]
http://www.lemondfitness.com/products/lewedge
The single best cycling product I have ever purchased!!!!!!!
Stephen Perera
Gibraltar, Europe
graphics@gibraltar.gi
Stephen Perera
Gibraltar, Europe
Re: Please comment on my aero position - UCI legal [Gary Tingley]
Looks cool, I'll have to see about picking a set up. I've reduced it thru drill work, but I still see it, esp when doign a long seated climb.
Thx a bunch hon.
AP
Thx a bunch hon.
AP
With all due respect, top riders are opening up their elbow width......not narrowing it over the past several years.
Re: Please comment on my aero position - UCI legal [Smitty8]
Tres interesting. (Thought I would throw in my limited French for Francois)
________________
Adrian in Vancouver
________________
Adrian in Vancouver
Re: Please comment on my aero position - UCI legal [sperera]
Hey Stephen
You look fast dude! Have you tried to run your arm pads with out the risers? I took the risers out and run the pads right on the bars. It gives you a better wrist/hand angle on the extensions. And I also found (I run A700 also) that if you take the risers out you can move the pad back some by using only one of the screws, so the pads are father back on your forearms, it makes it a bit more comfortable for me.
Rock on!
Dan…
A.K.A bikedude
Rock on!
Dan…
A.K.A bikedude
Likely to facilitate knee clearance, as seen in these photos. If a rider can mange it, closer spaced elbows will reduce frontal area.
"closer spaced elbows will reduce frontal area"
How so? I don't understand.
Re: Please comment on my aero position - UCI legal [bikedude]
good point Dan, I will test it and see.....I definately have an issue with the angle of the wrists and lowered them because of it.....
Stephen Perera
Gibraltar, Europe
Stephen Perera
Gibraltar, Europe
""closer spaced elbows will reduce frontal area"
>> By reducing the frontal area, making the cyclists lower and more narrow, the rider becomes more aerodynamic ... usually
Adrian wrote: What would be a ideal value for how much lower the top of the elbow pads are from the top of the saddle?
Slowman has a formula on his site about tri-bike fit. This isn't a tri-bike, but, it might yield some good information.
FWIW, I measure saddle to armpad drop with a level and a ruler. Just put the level on the saddle, make sure the bubble is centered as you hold the end over your arm pads, and measure the distance from the bottom of the level to the arm pad.
Quid quid latine dictum sit altum videtur
(That which is said in Latin sounds profound)
