Swimming experiment produces unknown advantage.
Swam nude this morning see if that would reduce drag. Drag remained the same but my steering improved.
customerjon @gmail.com is where information happens.
Re: Swimming experiment produces unknown advantage. [Mr. Tibbs] [ In reply to ]
You normally swim in drag?
That could get yer ass kicked in Texas!!
Cousin Elwood - Team Over-the-hill Racing
Brought to you by the good folks at Metamucil and Geritol...
[reply]Swam nude this morning see if that would reduce drag. Drag remained the same but my steering improved.[/reply]
Depending upon the size of that keel you might be harder to tip over in those mass starts also. Would itonly be a warm water advantage? But, in contrast, would it give the competitors something else to grab to slow you down? Better cogitate on the pros and cons before using on race day, at least in an A race.
Thanks for the laugh
Frank,
An original Ironman and the Inventor of PowerCranks
Just in case you plan on further experimentation, I don't recommend running in the nude.
Might help keep your hips higher in the water, due to the planing effect.
_________________
Dick
Take everything I say with a grain of salt. I know nothing.
uhh thats probably going to slow you down. you just can't put a keel on a boat anywhere and expect it to go faster. It needs to be hydrodynamically designed. From your previous posts you've mention that your length to width ratio is all wrong for increasing hydrodynamics.
Brian Stover USAT LII
Accelerate3 Coaching
Insta
Re: Swimming experiment produces unknown advantage. [desert dude] [ In reply to ]
My "Keel" didn't even touch the water even though I was nude.
