P2K cable routing/ferule problem
I like to use a ferule on the end of cable housings because this makes the cable action so much smoother and "contains the raw housing end", but I do not know which one to use where the shifter cable goes into the frame on P2K. Have tried two kinds with no luck. The ferule just sticks out at a crazy angle but without it the raw housing is scratching the frame/hole. Yuck!
What do you do abt this?
Re: P2K cable routing/ferule problem [danb] [ In reply to ]
There are two kinds of cable housing, thin and thick. Use the thin housing, and you will have more than enough room for the ferrule in the Internal Cable Stop of your P2K.
Gerard Vroomen
3T.bike
OPEN cycle
