Marcello,
I bought my P3 from
www.all3sports.com. I must say they packed the bike better than any other place I've ever mail ordered a bike from. It took me every bit of 45" to carefully remove all the protective wrappings. They took extra time and care to make sure this bike of beauty made it to me unscathed.
After successful extrication of the bike, assembly was straight forward and easy. First I mounted the front brake caliper, then the front wheel. Next I mounted the cowhorn/aerobar set-up onto the stem. All cables were already adjusted. Next was mounting the aerobar pads onto the aerobars. I chose the Profile Design Carbon Strykes due to their unlimited adjustability and because I'm not a big Syntace fan. Next I had to insert the seatpost and here is where I discovered I had to cut the post down. Since it was late, I decided to do this first thing in the a.m. when I was fresh. I consulted with forum members and with Cerevlo's website and with the input I received I easily cut down the post to my size. The bike was now assembled and ready for it's maiden voyage. Bottom line, you don't need to be a gearhead to do the final assembly of this bike. I hope this helps you and if you are at all considering mail ordering a P3, I'd say go for it and you will be quite happy!
Team Endurance Nation
