rim-drive trainers
I borrowed a trainer from a friend just to try it out and it's not as bad as I expected (having never ridden a trainer other than during a bike fitting). It's a Minoura InterRim rim-drive model -- a pretty cheap trainer. I hadn't seen a rim-drive trainer before, so I'm wondering what the pros and cons are. Obviously, this type of trainer doesn't put wear on the tire. Plus it can be used with knobby tires (not a concern for me). But does it put excessive wear on the rims? Is the ride quality much worse than a regular trainer?
And while I'm on the subject, I'll take some trainer recommendations. (A CompuTrainer isn't in the budget right now.)
Re: rim-drive trainers [Ariel] [ In reply to ]
Don't know a thing about rim drive trainers, but as far as recommendations go, I don't think you can do better than a Kurt Kinetic. Quiet, smooth, good customer service, offers a very road-like feel. I got one at Christmas and have used it extensively since then.
RP
I also don't know anything about rim-drive trainers. It does sound like its for the the mtb crowd.
I have a CycleOps Fluid^2 trainer which is pretty nice. It's reasonably quiet and has more than enough resistance. As mentioned lots of people like the Kurt Kinetic trainer which seems pretty similar to the CycleOps. There's also the 1up trainer. As I recall, this one is supposed to have a little better than average road feel---you can actually coast for a few seconds without losing too much speed.
I got a 12$ tire from chucksbike(s) so I don't concern myself too much with tire wear.
Meg.
Re: rim-drive trainers [Meg] [ In reply to ]
Do you change the tire every time you switch between road and trainer? Is that a major pain? Would it be reasonable to have a separate (cheap) rear wheel for trainer riding? Or is that silly?
First, maybe I'm naive but significant tire wear from a trainer is not a major issue. Well, in my experience it hasn't been but significant is also a relative word. Second, assuming you can afford some and have only one bike, having a 2nd pair of wheels for training, in general, is probably the best answer, imho. You wouldn't be switching that often since your "racing wheels" would only be used on occassion throughout much of your training. Thanks, Chris
I third the I don't know anything about rim driven trainers response. But that said, I ride my trainer at least 2x a week and have for several years. Only riding outside generally on the weekends. I have never switched out wheels for training and racing and have never had a problem. For the record I have Rolf Vector Pros.
Cyclops Fluid and Kurt Kinitec are both good trainers and both over $200. The Poasties use Taxc Swingforce ($179) so it can't be too bad.
This year I graduated to a computrainer after 2 years with Cyclops. It's awesome and with their payment plan doesn't make it seem so expensive.
Hope this helps.
I actually do own a Minoura rim-drive (magnetic resistance) trainer. I'm not exactly sure it's the same model as the one you tried out, but I'll give you $.02, for what they're worth.
I like it. I can throw either of my bikes on it, which have different rims and tires and have no adjustments to make, as far as wheel contact goes. The rim contacts are essentially "rollerblade" wheels, spring loaded against the rim, which can be locked out of the way while loading and unloading your bike. One of the drive wheels is attached via belt to what is basically a small generator (don't think <i>that</i> hasn't gotten my EE mind running on how to tinker with it and for what purpose to usurp it). Contrary to some comments I've heard, it doesn't get easier to pedal the faster you go, as each pole of the resistance windings pulls back fairly consistantly. Obviously, I haven't whipped out a force gauge to actually test this, but going by feel during workouts, that is what I've noticed. You also can't build up much momentum, as, whenever you stop pedaling, regardless of pace, your rear wheel will stop spinning in one to two rotations.
As far as wear on the rim, because the drive wheels are pretty low durometer rubber, the odds of damage to a standard aluminum rim are pretty much nil. You can get the wheels to slip occasionally, however, during start-up and if you break too hard, which might concern me if I ever used it with carbon wheels. Honestly, the occasional spin out of the blocks, though, is hardly a concern considering what effect breaks have on wheels you adjust the drive wheels to work on the breaking surface of your bike's wheels. The one exception I will add here is that if you have a painted rear wheel, you will wear off your paint more rapidly than breaking alone would. This, of course, depends on how the wheel is painted and with what paint, but with more constant contact than occurs during breaking, the paint can be worn through fairly quickly, again, with no damage to the underlying metal. I doubt the same effect would occur with color-anodized wheels, but have not tried them out to date.
