hiro11 wrote:
I'm more of a road rider than tri guy, what's the tri cognoscenti's view of the current Jan Heine/big fat tubeless tire theory that's starting to gain traction among roadies? I'm digging 36mm tubeless tires at 50 psi a great deal. Perhaps a bit extreme for tri/tt, but perhaps 28mm tubeless at 80 psi?As fat as you can go is GREAT for mixed surface type riding, even with no knobbies. I was enlightened to that fact after taking a 3T Exploro shod with the WTB "road plus" slick tires for a jaunt on the MTB single-track at the Interbike Outdoor Demo this year (thanks SuperDave!). It's what inspired me to ditch using the 700C rims with 32C Gravel King tires on my "all-road" bike for some 26" wheels with the Rat Trap Pass tires I showed above. With the much lower pressures allowed, and the flexibility of the casing, the control and traction off-road are actually quite mind-boggling.
That said, I'm talking about what one wants to use on something that will most likely be taken off-pavement, including relatively rough single-track...something you're not going to do for tri (except Exterra, of course ;-)
Jan would disagree (based on his somewhat crude tunnel testing), but there IS an aero hit to going too wide for that application. I would defer to Josh's "105% width" rule of thumb that he developed when he was at Zipp (where for best aerodynamics, the widest part of the rim shouldn't be less than 105% of the mounted tire width - or, in other words, the tire shouldn't be greater than 95% of the widest part of the rim). There just isn't enough Crr to be gained from running wider tires for the typical smooth (relatively speaking) surfaces of tri courses.
