sure, the new chart works almost exactly the same as the old one...only better.
your profile coordinates don't directly plug into the chart, which operates from pad stack and reach as the primary inputs...so I quickly CADed yours up from the profile info and I'm getting pad stack of 755mm and pad reach around 490mm. I will note, though, that something doesn't seem quite right in your profile #s...I'm guessing your pads-to-shifters was taken from the front of the pad not the back. math doesn't work out for your total cockpit length vs saddle-to-pad plus pad-to-shifter even with the angle adjustment for your pad drop.
anyway...
those pad coordinates above are actually slightly off the chart...an XL with the high-near stem and the tallest monospacer tops out at 740mm. if those 15mm are non-negotiable, I'm afraid we can't get up to where you are with the fully integrated cockpit. at the same time, with the use of the false steerer accessory and an appropriate standard stem length and rise, I'm confident a bar system like our
RXL Carbon Aero can get there.
Carl Matson
