OK so now you can go out and test and tell us (1) what your CRR is on the chip seal and (2) optimal PSI for the chip seal. I'm genuinely curious.
The good news is it is at its worst when first done and then slowly improves. After a year it won't be nearly as bad, though it will still be bad. If you can turn it into a bicycle safety issue you might be able to get them to reduce the size of the aggregate a bit.
