This. And on the other end, when I wanted to sharpen fitness, I'd destroy myself on group rides.
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [velorunner]
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [Carl Spackler]
Carl Spackler wrote:
This. And on the other end, when I wanted to sharpen fitness, I'd destroy myself on group rides.'This' what? Quote vs Reply, one is simple to follow and the other requires you to scroll back through countless posts to figure out what you're on about.
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [Mudge]
I guess you’ll have to use your imagination or ingenuity.
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [Ex-cyclist]
Ex-cyclist wrote:
synthetic wrote:
imswimmer328 wrote:
Those race group rides are great at getting you tired. Done properly they're a great place to learn how to ride among a group. They're not nearly as good at getting you fast as most think they are though. If all you're trying to do is have fun, then fine. If that's what get you actually on your bike, then no doubt you're faster than if you didn't go. If you're trying to optimize performance, that's not the way to do it. When was the last time you spent 40+ minutes at threshold in one of those rides? Preferably time accumulated in chunks >10 minutes. Also, I know I'd never be able to properly do vo2 in a ride like that because I'm barely able to pedal after each rep, at which point you're out the back.
This post sounds conflicting as you are saying it's too hard but then also not hard enough. My best is 30min on these rides, they are taxing, and demoralizing as there are older folks who can hang longer.
Not really conflicting if you understand physiology. Maybe it would be better stated as, "Group rides can be very taxing, but the work is not specific. Since it is not specific, you're not going to get the right stimulus you might need to improve"
^^^ This. Even Van der Poel, racing and crushing the field, went back to training so he could get more fitness. No matter what one thinks, group rides will not get you faster.
Kiwami Racing Team
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [marcag]
Aside from this. They're doing far less than 80-90 days a year now. Maybe in the 80's-90's? Lemond really flipped the table over when it came to season planning by focusing on the Tour. This is the norm these days, apart from maybe Pog. More than anything, these guys generally spend about 50-60 days a year at altitude training and doing.... wait for it..... intervals.
Here is a TDF rider
They absolutely do intervals. In fairness this isn't during race season.
12 minute intervals, alternating 2'30" at 35-370w 40/50rmp, 30" 470w 100 rpm
Heath Dotson
HD Coaching:Website |Twitter: 140 Characters or Less|Facebook:Follow us on Facebook
marcag wrote:
jollyroger88 wrote:
Pro cyclists have 80-90 yearly race days; I have a hard time believing they are doing anything beyond base training on non-race days, let alone intervalsHere is a TDF rider
Heath Dotson
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [GaryGeiger]
maybe, but the skill of drafting in a tight fast pack can be easily lost with mostly solo training. I think zwift/rouvy should make a change to their drafting algo that completely takes off the tension when you are riding behind some body - so you can't grind pedal through other people
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [synthetic]
The skill of holding a wheel at speed and maintaining a good position in the pack is vital for any racing and is easily lost unless you do a group ride regularly.
I've been on many good and bad rides. The bad ones were where people were obsessed with not getting dropped, never took any risks and aspired to be MOP wheel followers. Attacking after a sprint point was a favorite tactic.
The good ones had a good warmup and a couple of regroup points. People pushed their limits and got dropped but knew they had a chance to get back on. Usually you'd end up in a group of 8 or 10 doing a double rotating paceline for for 50 mins or so. You'd be chasing another group or holding off chasers. Only way to go fast was working with others to go as fast as possible. Great for improving timing, riding efficiently, working the top end and figuring you how to recover while in the red. Some of the best training you can do.
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [thatzone]
No intervals worked for Eddy Merckx.
But that guy raced in the 60s and 70s, and our understanding of performance has progressed.
In my 2022 rides, where I had a power meter, my group rides tended to be a lot of time at low power (endurance ish pace), and maybe 20-30 minutes at or above threshold. That’s not quite enough to build time to exhaustion around threshold. In contrast, the club’s faster ride would have had me probably riding at tempo pace in the bunch, and then going way over threshold in the 30 seconds I was able to stay at the front.
Everyone’s zone distribution is going to vary depending on them and the group, and their response to training is also going to vary. The point is my group rides weren’t productive for me in 2022. In 2023, I specifically worked on TTE. But I also dropped my power meter, so I don’t know exactly how hard I was working at the front - I think I was probably around tempo pace most of the time if I was on the front (for the faster group, I just tried to hang on for dear life and I would spend maybe 2-3 minutes at the front at most).
I think it’s illustrative to read Joe Parkins account of learning the ropes as a young professional in Belgium. Their training was lots of miles, mostly easy, mostly flat. Occasionally the side by side team rides would force thresholdy efforts, though no one called them that. And they raced, a lot. Eventually Parkin returned to the us and raced mountain bikes. He participated in an Olympic camp in 96 and had the revelation of pre season intervals with a hr monitor.
Intervals have been around in cycling since at least the a 80s. Further back in running. There will always be people who succeed without intervals. There’s no replacing talent, or a professional’s calendar. But for the rest of us intervals probably help.
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [Titanflexr]
Titanflexr wrote:
synthetic wrote:
imswimmer328 wrote:
That's a pretty common misconception though. You're rarely doing as much work as you think you are on group rides, no matter how many attacks you do, and it tends to be relatively one-dimenaional.How many crit races have you won?
A crit is the hardest interval workout you can do.
Even the "wednesday night worlds" local group rides can be brutal. The one by me has a small hill a few miles in that takes 400W+ for three minutes just to not get spat out the back, and that's early going with no one trying to force a selection.
Is that what used to (~20 years ago is the last time I rode it...) be called the "muddy ride" in San Jose on Santa Teresa Blvd?
Re: Is Chris Horner's NO INTERVALS the way dinosaurs trained? [sebetri]
A bit further north; the PenVelo ride from the reservoir at Canada/92. Lots of great local rides all over South Bay. There is the famous noon ride, but I've never even thought of trying that one (too many pros).
ECMGN Therapy Silicon Valley:
We were talking about this video on a run last night. A lot more questions than answers but a lot of insight too. Some things that were brought up:
-It's not that 'no intervals' is ineffective, it's that it *could be* less effective than structured intervals. This is nearly impossible to measure tho, as group rides and intuitive training are not easily replicable. A very good rider doing 95% effective training will still find himself at or near the front of the pack.
-The point of doing intervals is to control the specificity of training. A world tour cyclist almost by definition has a good intuition of what training should be to compete in world tour races. "Doing Madone 3 times kinda hard" may not be called interval training, but a power graph of that ride and 3x40min @85%FTP are practically the same.
-Very probably, for a top tier cyclist, it's going to be likelier they to go too hard than too easy. Interval are a tried and true way to control this.
-Group rides frequented by a bunch of triathletes on Slowtwitch are not a good representation of group rides on World Tour teams. World Tour racers will know how a World Tour race goes, and one should reason that their group rides by and large reflect this racing.
mathematics: Feb 1, 24 8:14
