Zenmaster28 wrote:
Hi Eric, great thread! This is for my wife, she is currently on a 2011 Cannondale Slice size 58 and wants to switch to a Cervelo to complement her S3 and Caledonia.
Pad X - 530 to center from a fit sheet, I can measure actual to back of pads (PD Ergo) if needed
Pad Y - 625
She does not like the look of the PX series so P5, P-series, NP3 would be the type she'd consider. She doesn't do triathlon, purely TTs which mostly don't care about UCI regulations but may occasionally need to squish into a UCI compliant position.
Hope that's the info you need and thanks for any advice!
Pad Stack of 625mm and Pad Reach of 480mm is long and low, a good TT position. With those numbers she could fit on a 54cm (reach maxed out), 56cm, or 58cm (stack slammed) P5d.
I’d not recommend the 54cm, but a case could be made for either the 56cm or the 58cm, with the 56cm being closest to UCI compliant of the reach exemption. She’d have 15mm of more reach to play with on the 56cm or 15mm of less stack on the 58cm.
So, 56cm... make sense?
Eric
