ABarnes wrote:
HUZZAH!! not to talk too much about the squishy stuff, but allowing the toe to float (especially in the critical 4th quandrant of the stroke) independently from the heel can be magic.
Shimano blue cleats hint at this, but with only a total of 2degrees of float (and that means only 1 degree from center in either direction) it's marginal.
Except for Speedplay and Time, most cleats are fixed at the toe regardless of how much float is offered.
There is so much misunderstanding about float, and float ranges, I look forward to your article Slowman!
I'm confused. How does the toe float independently of the heel? The shoe is rigid, and the cleat rotates around a fixed point in the cleat.
Shimano yellow cleats float more at the front of the cleat than the blues. That's where shimano cleats allow their movement. Look's allow the movement at the rear, or at least they did the last time I looked at them. But neither are at the "toe", nor is Speedplay, they all have pivot points within the area of the cleat. Speedplay is in the middle, look at the front, and shimano at the back.
The only system that doesn't have a fixed pivot is Time, as I recall, which allows the "virtual pivot point" to be almost anywhere.
Swimming Workout of the Day:
Favourite Swim Sets:
