Re: Which brand of Latex tubes? [TravelingTri] [ In reply to ]
TravelingTri wrote:
Does anyone have any experience running latex full time. Is this possible/advisable?
It would be one less thing to "change" right before my race. I am riding pancake flat training so heat buildup in descents won't be an issue (if that is one, so I hear). Don't mind pumping up every ride so not concerned about that either.
Yes it is fine. If you are riding latex though in training chances are you are interested in going fast. In which cases you should probably be swapping out tires as well for races.
Re: Which brand of Latex tubes? [TJ56] [ In reply to ]
Challenge makes latex tubes for 700x38 tires.
Re: Which brand of Latex tubes? [svennn] [ In reply to ]
svennn wrote:
Thomas Gerlach wrote:
NewbieTri100 wrote:
Which brand of latex tubes would you pair with GP4000iis 700x23 on HED Jet Black 60/90 and Disc?
Are they all basically the same or are the Vittoria, Bontrager, Specialized, or Michelin's any better than the rest?
Thanks for you recommendations!
I have used them all and have been on Vittoria Latex for the last many years. Although Josh at Silca is coming out with some branded latex tubes which are *pink* but have shorter valve stems which would be ideal for disc rims.
Wow, $25 per tube at Amazon right now. I need some for this season but at that price I be shopping elsewhere.
It looks like Micheline is a good deal from overseas at around $8 per tube.
Yeah you can usually find them cheaper overseas. I am not fan of Michelin for the fact they don't have removable cores.
Re: Which brand of Latex tubes? [hblake] [ In reply to ]
hblake wrote:
My question is are latex tubes patched the same way as rubber tubes?
Thanks.
It has come up before on here but this isn't something I have done. It can be done from what I know but I never have tried and can't speak to it.
Re: Which brand of Latex tubes? [Thomas Gerlach] [ In reply to ]
This.
Consider the specific use. For example, a H3/Renn combo is perfect for the Michelin because the Valve Stem is the perfect length. For deep wheels, Vittoria/Challenge would be preferable due to the RVC.
Re: Which brand of Latex tubes? [P McCatty] [ In reply to ]
This.
Yep and I am pretty sure this is where Josh at Silica found an opportunity to make latex tubes providing a Vittoria like durability and RVC, with the shorty stem of Michelin.
This.
Silca makes latex tubes? Did I miss something?
blog
Re: Which brand of Latex tubes? [stevej] [ In reply to ]
I have two that were sent to me to test out but no idea on future availability of sale to public. If I had to guess they are made by Vittoria to Silca spec with a shorter valve stem. I haven’t seen anyone else talk about them and maybe I wasn’t supposed to mentioned it but I did. Can’t put that genie back in the bottle.
 Interesting. I was hoping about a year ago that Silca would come out with their own. If they come out with a shorter valve stem, I'm going to have to redo all my valve extenders. :(
Thanks
blog
The best way to patch latex tubes is by using a bit of an old latex tube and superglue.
Normal tyre glue squirms and the patches usually develop slow leaks.
Superglue just works and is ready in seconds.
Re: Which brand of Latex tubes? [NewbieTri100] [ In reply to ]
I really like Challenge latex. Removable valve cores, never had a bad one, good selection of sizes, and not too expensive.
Re: Which brand of Latex tubes? [FindinFreestyle] [ In reply to ]
It has been about six years since I used a Challenge latex tube. Do they still come with greasy coating?
what is the stem length on the Vittoria's?
Re: Which brand of Latex tubes? [tlc13] [ In reply to ]
51 mm
blog
51mm
http://www.chainreactioncycles.com/...r-tube/rp-prod124087
I just noticed my local shop has these for about the same price as Vittoria. I think I'll try them out and support my local shop some.
They are talc-ish just like the Vittoria or Michelins. Doesn't talc get greasy if wet? Anyways, I'm another who like Challenge...
Re: Which brand of Latex tubes? [woodys737] [ In reply to ]
Sounds like the formula has changed since I last used them. They definitely were not talced way back when like Vittoria, Mich, and Vred.
I noticed a change whenever their packaging changed about 3 years back. When they went from the clear plastic "case" to the paperboard boxes there was a distinct change in the tubes. Tubes seemed less translucent (more pink than red) and also had more talc pre-applied. I currently use the 28-35 mm Challenge tubes for my 25 and 27 mm road tires. My 23 mm TT tires I use the 19-23 mm Vittoria tubes.
Re: Which brand of Latex tubes? [GingerAvenger] [ In reply to ]
A yes, I was used to the clear plastic case. Sounds like they definitely changed the formula, may have to try Challenge now too.
Going to give Vittoria latex a shot. Never used rim tape before and read it's suggested to use with latex. Any recommendations on brand and size? Velox rim tape 16mm good? Zipp 808 wheels
Re: Which brand of Latex tubes? [TriathleteWes] [ In reply to ]
I don't like the cloth rim tape myself - I much prefer Stan's Rim Tape. Stan's 21mm tape should work depending on which wheels you have.
Could you tell them to make long stem ones too? That is the unicorn a lot of the deep dish wheel users want. Some 80mm stems and 110mm (or so) versions would be great to not deal with valve extenders.
Silca latex tube info on Bikerumor: https://www.bikerumor.com/...ew-larger-seat-roll/
