Re: UCI saddle setback 5 cm. What's yours​? [Fishbum]
6cm on ISM PS 1.0
5.01cm on specialized power saddle.
Re: UCI saddle setback 5 cm. What's yours​? [pabloarc]
12cm on a road bike for early long stuff,10cm if I am racing.
TT is always as far forward as allowed.
leegoocrap: Apr 10, 17 3:46
Re: UCI saddle setback 5 cm. What's yours​? [leegoocrap]
leegoocrap wrote:
94mmWow. On a TT bike?
leegoocrap wrote:
Fishbum wrote:
Is your fit drastically different than most?
*track bike, TT bike is pretty close, I think it's closer to 90.
I assume it's not a common fit these days, it's certainly not something you'd come to from a fit session or a Retul bike.
My Blog - http://leegoocrap.blogspot.com
14 cm
Uci rules aren't the constraint these days - the mfrs are.
Kraig Willett
http://www.biketechreview.com - check out our reduced report pricing
Kraig Willett
Re: UCI saddle setback 5 cm. What's yours​? [BikeTechReview]
BikeTechReview wrote:
14 cm Uci rules aren't the constraint these days - the mfrs are.
I really expected more 2 to 4 cm
2cm on an adamo racing saddle.
Depends on the saddle.
4mm on a ISM prologue.
WD :-)
WD :-)
In correlation to body height / leg length would be interesting .. with me it's close but would not be UCI conform on my roadié with 191cm and maybe a little bit long legs .. riding Flite since 20 years ..
___/\___/\___/\___ the s u r f b o a r d of the K u r p f a l z is the r o a d b i k e .. oSo >>
sausskross: Apr 10, 17 4:57
75mm with a Pro trisaddle. Height is 188cm.
25mm on Adamo Road. 190cm height.
Re: UCI saddle setback 5 cm. What's yours​? [sausskross]
One reason I reduced setback over the last years and got a little bit higher therefor is my stomach, the second is getting my nose more out of the wind because of the speed and the third is a proper balance to accommodate the race geo of my Luzié ..
I am 40mm on a Fizik Arione saddle. That is with the saddle as far forward as it will fit on a ~20mm setback seatpost. I basically duplicated my 30-YO road bike setup, so I have no idea if this is a great fit. But I was very fast and won a lot of races in the day.
25mm with a Sitero on my tri bike, which gets me in the same position as the previous "conventional" saddle (Selle San Marco Aspide Tri) which was 40mm ahead of the BB...
"I'm thinking of a number between 1 and 10, and I don't know why!"
Mine is 3.5cm ... but in Oregon, you don't have to worry about the 5cm rule! ... Unless you plan on racing outside of the state.
I'm using a Specialized Power Pro saddle and am 180.34cm tall (82.44cm inseam).
Are these numbers behind the bottom bracket?
Robert Driskell
Certified Master Body Geometry fit Technician
Certified Master Retul Fit Technician
Zipp Service Course Specialist
Bikes Plus Pensacola Florida
Robert Driskell
Re: UCI saddle setback 5 cm. What's yours​? [Robert Driskell]
That's on the prologue I mentioned on my post above :-)
WD :-)
