Q-Rings incompatible with SRAM etap?
Guys
I am a bit desperate, I bought the new etap try group and mounted in with my Rotor Q-Rings, now my chain comes off when upshifting. Spoke to SRAM and they said etap was designed to work only with Sram...Might be my fault for not checking beforehand, but, has any of you managed to get this working somehow?
I am still waiting for Rotor's answer.
Thanks for your help
Re: Q-Rings incompatible with SRAM etap? [pablofuente] [ In reply to ]
play with the adjustment screw on fd
Re: Q-Rings incompatible with SRAM etap? [R2] [ In reply to ]
Thanks, have you managed to make it work that way?
I had Rotor Q-Rings on my Cervelo S2 w/ Ultegra Di2...had a lot of trouble getting good shifting for a long time (was traveling, that didn't help) and I wasn't capable of tuning it correctly, nor could I find good info on why it wouldn't line up.. Finally got it done well at a good shop when I returned home from traveling, and it was great. I know they are different mechanisms but I can't believe it's not possible.
+1
I am running eTap and Q-Rings on 3D cranks without a problem.
Re: Q-Rings incompatible with SRAM etap? [DeeJott] [ In reply to ]
Guys
3 different mechanics have seen the bike and tried...so, can you please help me and tell me how did you do it?
Is you could upload video or photo would be fantastic!!
Thanks a lot
LBS did the install, so I don't know if there was any 'secret installation sauce' involved.
I am sure you have seen the SRAM install video.
I did watch the video so the mechanics at the shop. Would appreciate if you can give me a contact name at your LBS for me to call them.
Thanks a ton
Call Philip Shama, brilliant guy at
Shama Cycles in Houston, TX
713-812-7633
info@shamacycles.com
THANKS!
Hi, did you ever get the Q Rings to work on the SRAM etap's ?
Re: Q-Rings incompatible with SRAM etap? [RITTE67] [ In reply to ]
i did works like a charm
Fantastic !!!. Did you install the OCP3 (SRAM) 50/36 Q Rings, or do you have the classic Q Rings with various OCP settings ?
Do you get any rubbing ? or chain suck ?
I tried the Q Rings before on RED 22 and had some issues with the FD.
Mark
I found I have a slightly different issue, I've set my upper limit while in 53/11 to just barely eliminate any rub. Shifting from small to big if I am turning the cranks too slowly or stop, shift, wait, pedal, the chain never makes the jump to the big ring. While spinning the cranks with a little bit of force during the shift the chain makes the jump over. Any thoughts?
Re: Q-Rings incompatible with SRAM etap? [aavlee] [ In reply to ]
I'm running it on both road- and tai-bike with O-Symmetric 38-52 setup and that is much more extreme then even the QXL ones. You definitely should be able to get it running sweet without rubbing.
I did post some pics of the setup on my P5 somewhere on the forum. If you search for eTap posts under my forum-name, you'll come across them.
Greetz,
S
pablofuente wrote:
Guys
Thanks a lot
These so called guys are Bike mechanics??
at Walmart???
Trying since 81
Re: Q-Rings incompatible with SRAM etap? [Magma] [ In reply to ]
Guys
I still did not manage to make this work, so ended buying the SRAM rings...I'd still prefer the Rotor Qrings. Any help is much appreciated.
I believe etap is no different than mechanical so it should fit.
1.-Take the chain off and unscrew the derailleur clamping screw and push the cable aside.
2.-Turn the inner limit screw fully in so the derailleur moves outwards.
3.-Lightly unscrew the screw that fixes the derailleur to the frame so you can make adjustments
4.-Turn the derailleur so the markings in the top of the derailleur are aligned with the largest ring when looking from above.
5.-Then move the derailleur up or down so the widest part of the ring is aligned with the markings in the inside of the derailleur. This is the only part that is specific to the Q-Rings. Check that you haven't messed with 4 when doing 5.
6.- Tighten the clamp checking that you are not messing with 4 (sometimes the derailleur rotates when it is tightented)
7.-Put back chain, adjust the inner limit screw so that the derailleur barely misses the chain when in the small ring and big cog combination. Pull the cable, tighten the screw and you are good to go.
Hello pablofuente and All,
Nytro in Encinitas set up mine and works just fine. (original Rotor Rings type)
https://www.nytro.com/
800 697-8007
Cheers, Neal
+1 mph Faster
Re: Q-Rings incompatible with SRAM etap? [argmac] [ In reply to ]
No etap is not set up same way as mechanical
My LBS set me up with a 53/39 Rotor Q Ring and Etap on my cervelo S3. Works wonderfully.
According to sram's setup video it is the same as the yaw mechanical. Except for the obvious which is the cable adjustment. All that I described applies to etap.
Thanks a lot guys
Argmac, great stuff the detailed instructions...I am hopeless though, my LBS tried and tried, they say they cannot manage.
I am the first guys they've seen with etap, and first one etap+Qrings....
Take a look at this video https://www.youtube.com/watch?v=XlLwu-SDo5w and take into account point 5 of my previous post.
whats the chainrings you use maybe to big step like - 34 - 53?
